Furnace Inferno
I’ve finally got around to remembering to switch the HDMI’s on my Lumagen, now rather than splitting off the audio to my Lyngdorf processor and the Lumagen direct to the projector, I’ve just got the one output from the Lumagen to the Lyngdorf and then the Lyngdorf to the projector.
I watched Challengers a couple of days ago and had one audio dropout near the end which reminded me I needed to try swapping. Today I watched Speak No Evil after changing and no dropouts, will need to try some more movies to be sure but I’m hoping this has now fixed the issue.
After reading the Lumagen and Kaleidescape threads in regards to the Strato C that also had audio dropout problems, I can only surmise the audio only output on the 18Ghz boards which is limited to a 720p signal is causing some kind of intermittent syncing issue with certain hardware combinations since it’s fine on my Zidoo, Firestick and PC but not on the Strato V.
Next thing to adjust is the green screen/flicker when the output changes as that is super annoying in a blacked out room!
