- Joined
- Nov 27, 2023
- Messages
- 2,299
I currently have a 105" fixed wall-mounted screen (due to physical limitations). I'm planning to replace this with a retractable screen (w/retractable tracking) with a "default" screen size of 135" at 16:9 ratio. This will be a "Constant Width" solution with the default screen as tallest and everything else masking down (all the way to 3:1 if desired - I'm looking at you Dust Bunny!).
Before I pull the trigger, I'm wondering if I should get a taller screen to facilitate additional aspect ratios. Based upon preliminary measurements, I think 1.66:1 might be the only additional option as my projector doesn't have the throw distance to handle 1.5:1 or 1.43:1. I'd be using lens memory on my JVC projector to accomplish this so as to not lose light on other aspect ratios, with everything else going through a to be acquired Lumagen. So, really, we're talking some Bond films and a few dozen others? Any folks in similar positions?
I'm still waiting to hear from Stuart Filmscreen if this is even an option, but I figured I'd check in with you fine folks to get some thoughts. Thanks!
