I’m not sure if this is the right place to ask for help with this but it seems to be a Kaleidescape issue and any help would be greatly appreciated. I’ve spent days trying to troubleshoot this and I’m stumped. Equipment being used is Strato V, Altitude 16, Envy Core MK2, NZ700. I’ve read and reread all the MadVR setup guides and I believe all the kscape settings are correct but the MadVR is reporting incorrect aspect ratios on the incoming signal. It seems to be intermittent also. For example I play Gravity which is 2.40 and sometimes MadVR sees it correctly sometimes it sees it as something close like 2.38. The other odd thing I’ve noticed with the Kaleidescape menu is it comes up filling the screen correctly but after a few seconds switches ratios on the input and MadVR resizes it and gets partially cutoff the screen. I can send photos, videos or whatever other information is needed. I’m available for conference call if needed as well.
