As you all know, Kaleidescape no longer makes blank drive cartridges.
But they are an absolute must-have if you have a 1U, 1U+, or 3U server.
They must be used if you have any of these server chassis and you have empty slots in them.
These are used for cooling the hard drives.
Removing and Adding Disk Cartridges or Blanks
Server disk cartridge slots MUST be filled with disk cartridges or blanks. Disk cartridges can be added to expand server capacity or replaced as needed.
WARNING: Do not operate the server with empty slots. Always use blank cartridges to fill slots. Open slots compromise the cooling system.
Crucial Guidelines for Blank Cartridges
These are made of EcoCore.
EcoCore offers a locally sourced, environmentally conscious acoustic solution. Choose from a current palette of 13 stunning colors and ten wood grains, with even more options in development—ensuring your space is both visually striking and responsibly designed.
To be clear, this is for the EcoCore replacement cartridge, not the original Kaleidescape blank Cartridge!
They are $ 20.00 each. + shipping
- Cooling Requirement: You must never operate a Premiere server with empty, open slots. Every slot must be filled with either an active disk cartridge or a blank cartridge to maintain proper airflow and cooling.
