HERE IS MY LOCKDOWN 2020 EDITION SCRIPT. Still a work in progress
josh
can you add what movies are required for the script?
josh
Wow. Someone definitely has a lot of newfound time on their hands! :p I’ve got about 60% of the movies so I’ll try it! Thanks for sharing!
todo
Peter,
Hope you are doing well...
I could not load the lockdown script using IP/scripts on my Stratos :-(
Ash
CINERAMAX IOPH
Hi Ash, same to you! Try it today, I had similar issues 1 1/2 months ago, it's an occasional bug in the K dashboard firmware. Stay safe.
todo
Tried a couple of times, get this message:
"The current script does not contain any steps. Click Add Step to add one"
I need to figure out a way to report to K...
Thanks for contributing to the community - our choice is always the best and AVS is not the same without you.
todo
Peter - what worked was 192.1xx.1.XX/import_script
what DID NOT work was 192.1xx.1.XX/scripts
CINERAMAX IOPH
Great, That is the correct way, glad you figured it out. Let me know when you get through it, it may take a day. LOL Cheers!
JohnJ
It sounds like you have a pop-up blocker installed, Normally when you go to the /scripts page there is an “Import from File” tab at the bottom. When you click on it, it pops up the “/import_script” page. You can either disable the pop-up blocker or just go to it directly as you discovered.
JohnJ
This is a very nice Script! Lots of scenes that I enjoyed and nice to see a lot of scenes from most of the latest releases. This took A LOT of effort to put together - marking custom scenes and the putting together the final Script. VERY NICELY DONE! I, for one, appreciate the effort and your willing ness to share. Thank You!
Once this Script is finalized, it would be nice to get it loaded to the “Resource” page. Then we have one place to go to keep track of all Script and Scenes files. Also, this page keeps track of downloads and allows users add Reviews of the scripts/scenes.
Notes:
1.) Call of the Wild scene Avalanche didn’t load for me. However, this movie is one that I had an “Update” for (audio and video improvements) which I assume made what I have look like a different “version” from what is in the script (as pointed out by Kaleidescape pointed out would happen).
2.) Shazam! scene Power is in the script twice - with such a large script it‘s hard to keep track, I’m sure (my script ended up with 88 scenes but there are a few movies I didn’t have).
3.) it always amazes me when I hear Sherlock Holmes scene Voice. This has DTS-HD MA 5.1 audio but with Neueal:X upmixer it sounds fantastic - lots of action from the height speakers and very well mixed!
Again, thanks for this!
