Help Appreciated: Strato K Blacks Out After "One Moment Please..."
The Dark Shape
Los Angeles
Hi everyone. I've contacted my dealer and support about this and am hoping back for an answer soon (the problem just started yesterday), but I figured I'd ask here as well since you're much more informed on Kaleidescape happenings than I am and maybe there's a known fix I'm missing.
I ordered a Strato K, my first Kaleidescape, and it was delivered last week (as of now I'm just using the Strato K itself, no Terra servers). Everything was rolling fine until yesterday, when I hit back on the remote to exit a show. The Strato box went dark instead of the typical blue light when active and my Denon receiver said there was no signal from the input. My first instinct was to unplug and restart, very basic. I waited a few minutes and did so, then got a Kaleidescape logo and text that said "One Moment Please..." The blue light on the front of the box also returned. After about twenty seconds, the screen went black for a moment, then returned to the Kaleidescape logo and "One Moment Please..." For a split second my receiver indicated it was receiving a Dolby Atmos audio signal, but then the box went dark again, the screen went black, and my receiver once again said there was no signal from the HDMI input.
I've tried various things since then -- plugging directly into the TV instead of the receiver, doing a full power cycle unplugging everything and returning in 30 minutes, etc. But I always get the same result: "One Moment Please..." before no signal. The store website lists my system status as "OK" with last contact always updating to the last time I restarted, so some type of network connection is happening.
I did some searching and couldn't find anything, but I admit I'm ignorant. Is this something others have encountered that can be fixed with the right restart steps, or am I more likely looking at a hardware fault?
Thanks for reading this far! I really appreciate it. I absolutely loved the service while it was working.
Something to try. I also had lost the signal on my Strato K after it had been working fine for weeks. I eventually switched the supplied Audioquest cable with a Tributaries cable and everything is fine now and has been since. I feel the supplied cable failed and might not play nice with the K. Not bashing Audioquest as they are great for Audio.
Thanks for the idea, kimg. I don't have a Tributaries cable and couldn't get one today but I did swap in a couple different 48Gbps-rated cables and they didn't make a difference, unfortunately.
Is your Denon connected to a projection system or Tv?
I just noticed you did mention TV. I would suggest using a full fiber HDMI cable between the AVR and display to ensure a stable connection. This is usually the weakest link in the chain.
The supplied AQ cable is ok for the AVR/ Strato K bond.
Unfortunately I don't think that's it as I tried connecting the Strato directly to the display (a TCL RM9L) and cutting the receiver out of the chain, and it led to the same result. So it doesn't seem to be an HDMI cable issue, or if it is it's affecting the AQ cable and every other high-bandwidth HDMI cable that I have. I'll update this thread after I've spoken directly to my dealer and/or Kaleidescape.
I suspect this is a whole lot of troubleshooting and cable swapping for no reason. Based on the original description above, it sounds to me more like the following sequence of events has occurred:
Instead of a "Back" command to exit playback, you pressed the "Power" button which immediately halted playback and put the player into standby (thus, the extinguishing of the player's LEDs and the "No Signal" to the Denon.
With the player now in standby, when you power cycle the player, it reboots but boots into standby since that was the last state it was in when you cut its power and restored it.
You need to take the player out of standby by pressing the Power button on the remote again.
Looks like this was in fact a connection issue but seems like it was a bit of a glitch -- using the default AQ HDMI cable, forcing the Strato K's "4K & 8K Ultra HD Support" setting down to a max of 18Gbps restored the input signal, then I swapped back to Automatic, restarted the box, and everything's currently working well.
