CMCJO,
Yes, that is QUITE annoying. You will need to do some work in the AMX module I think. At a minimum, in touch panel designer, you will need to send a string output to whatever port your Kaleidescape is set up to on the system. When you want to see Kaleidescape info - presumably when you select it from the source selection screen - send the number 501 out in the string output field of that button in TP Design. When you want to turn off the dynamic feedback, send out 500 on that line. We have placed 500 on a great deal of buttons in the design. Virtually anything that could turn off kaleidescape - Main Menu Button, System Off Button, etc. The intent of this feature is sincere, but in multi-panel applications it is annoying. The idea behind it is that you are constantly seeing what is on the screen from your touch panels. Unfortunatly, out of the box, Kscape thinks every panel in the system wants to be updated when the Kscape is on.
After reviewing your original post, it would appear that you would not be able to accomplish what you are looking to do - IF you are scrolling movies on the same player. The feedback, again, hoping to force the panel to mimic the onscreen display, will track with whatever the player is doing. In my experience, we had all of the panels in the system (20+) going to kaleidescape pages when only one room was on that source.
You would be able to view music on one and movies on another if you have different players. If you only have one player in the system, any panel with feedback turned on will show the current onscreen output. This goes back to the original intent of the feature and from what I understand they never want a user to see one thing on a panel and another onscreen. The potential for confusion is there and it would negativly impact the user experience.
