Too late to redeem UV codes?
AlienW
So I decided to dig out all the little pieces of paper with UV codes from my BR cases. I figured that I should try to get them in my k store account if possible. So I created a new UV account through the k store and then...
How do you actually redeem these things into UV? The paper on most of them says go to https://movieredeem.com/ or https://redeemmovie.com/. Once I put in the code I get a screen that asks where I want to redeem. The choices are Itunes, Google, Vudu or Fandango Now.
But no UV... Does that mean that this code is not able to be redeemed on UV anymore?
They should still work. You could never redeem UV codes directly through the UV website, which never made sense.
I have a VUDU account tied to the same UV account as my Kaleidescape store account, and I redeem everything through VUDU.
It usually takes time for them to sync (maybe 15 minutes), but they should eventually show up in your Kscape account, as long as the title is UV-enabled in the K store and it's the same version (theatrical ,extended, etc.)
Thanks! I figured it out. Way too complicated... No wonder its not caching on. I now have accounts with UV, Fandango, Vudu, and MA. 23 movies show in my UV and 21 show up in the k store. MA has 35. That is coming to k any day now right? ;)
Vudu is pretty funny when you redeem a code, it says "You now own the digital copy of X"..... Yeah right I own it :rolleyes:
At least up unto about a year ago you could type it in UV and be presented with easy links on where to redeem.. not sure why they dropped that.
Kevin D.
