Hi Everyone,
I'm fairly new to this, only having had our K system for about 6 months now. It has been working very well up until tonight. I access the system via HDMI in our media room through a Crestron control system.
Tonight, I changed video sources from Sat to K like I've done almost everyday since we bought it. It changed to the K system, but would not move from the screen saver. I powered the both the control unit, and the server down, gave them about a minute, then restarted them. I repeated this process 2-3 times, with the same result.
I can access the system online, and it appears to be responding properly, except when I try to access the "Onscreen Display Control Panel". It says "The K component you have chosen to control is not responding. Please wait while the connection is re-established or choose another control panel from the Web utility".
It does not leave this message screen.
Any ideas?
Thanks, Kevin
Any ideas?
Thanks, Kevin
