Hi, apologies in advance for what is maybe a long winded question.
We have Crestron and have for years ‘started the Cinema Room up together with the auto launch of a movie themes playlist which you can listen to while everyone is sitting and settling down. Fairly simple stuff because the Crestron simply selected and powered up the Linn DS in the room and using it’s auto play feature it just played whatever was in its playlist (which was the movie themes). When the K was installed a lot of things changed including some re-programming and they forgot to reinstate that Linn ‘bit’. I can just get them to do that but it occurs to me that with the K that maybe there is a way of the Crestron powering it on and then playing the music or maybe better still a pre-defined set of movie theme clips with music. I know nothing about scripts but know they exist but before I get too excited I am not sure how easy it is for Crestron to start things up on K and select a pre defined script?
I would expect that to be easy enough but is it?
Or is there even a movie themes ‘movie/programme’ to buy and select in the store?.
As a example the playlist had things like Indiana Jones, Superman themes, Star Wars, Bridge over River Kwai, etc etc big sounding, very recognisable movie theme.
Ideally they want to be normal tune length. We also had the famous Pearl & Dean music in between each track which everyone seemed to love. The oldies at least.
The added benefit being able to see the scene as well on K would be cool but just the audio still works.
I thought I would ask the collective wisdom as I myself disappear down the into the digging around pit of despair seeing if I can work it out myself.
Am I wasting my time or is this easy?
