Slow download speed
mhbernheim
Anyone else getting slow download speeds today? Overlord is taking 866 days and 20mins according to the status page.
I have 120MBit connection
My speeds appear to be normal, but only two downloads today.
You might want to stop the download and do a hard reset on your system (power down, unplug for a minute and power back up). Might not help, but worth a try.
Okay, found something odd... overlord downloaded in 27 hours at 5mbps max... then other titles downloaded at 72mbps in less than 2 hours... apparently its something with “Overlord” kscape IT should check their CDN settings
Interesting, not sure why your speeds dropped like that, Overlord (HDR) downloaded to my system in 1h, 33 min. The HD version was 1h, 16min.
Overlord was fine downloading on my system (17 min HDR, 56 min HD). I am in Edmonton, so also a CDN download. I have had luck in the past, when there is a very slow download, aborting that particular download and re-downloading again.
Wayne
