From the previous thread(s), I ordered a:
LG Internal UH12NS30 BD-ROM
From Amazon. Installed that and a fresh battery in an M500 a couple days ago. I got no speed increase ripping DVDs. The drive I replaced was a Sony BD-5300S, which interestingly is a rewritable drive. It was working fine, but I had seen reports that ripping might be faster with the above, so I tried it.
Note that if you replace yours, you will want to pop the front door off the new drive. The ones I bought remove easily by pulling out on the front edge and pushing upward (with the drive open, but I believe in both cases they drive WILL open with the front door in place, it just won't close without catching until you remove it).
I also bought a:
Sony Optiarc 18X DVD-ROM Drive DDU1678A-0B
That was based on the previous thread as well. I think it was for a K5000 or K6000 and I bought it just in case. But then when ripping a TV box set of DVDs via my K2000 stack (I have three), I *kept* finding disks that the K2000's wouldn't read but my M500 would. Probably one in four wouldn't read in any of the three. So I took a leap and popped one K2000 open and replaced its drive with the above Sony. I didn't have TOO many more to do, but no more failed to read in that drive. So my guess is newer drives do work better than the old ones in the K2000's, or the ones in the K2000's are getting dirty.
What was interesting, though, is that the new drive was also not any faster for disks that worked, anyway. Same exact speed. Guessing the K2000 hardware doesn't spin it but so fast? The model that came out of the K2000 was a TSST DVD-ROM Drive SD-M1912.
The Sony I put in doesn't appear available any longer easily, though. But I did find some IDE DVD drives on eBay for so cheap I ordered a 10 pack ($25 shipped free for ALL of them and they are supposedly new) just to try. I'll report back if they work. At this point I don't have any DVDs to rip, though, so I gotta get a few I guess.
I probably have another half dozen used IDE drives laying around to poke at if these new ones don't work for some reason.
Note that the K2000's open up really easily. The M500 is only slightly more difficult as it needs a single safety allen screw removed (allen with a hole in it).
--Donnie
