Is anybody using this combination together with the internal co-star option enabled?
The reason I ask is that I continually have problems getting the audio processed correctly as it comes out as PCM 2.0 48K on the Datasat
If I take the Strato audio only out and feed the Datasat directly it works perfectly (all codecs, Atmos etc.) and if I take an audio output from the from the Radiance Pro and feed it to another input on the Datasat that works perfectly for the audio coming from the paired M300.
Perhaps I have missed something in the configuration as occasionally all works as planned but 99% of the time the audio is shown as PCM 2.0 48K on the Datasat if I don't use the workaround.
