Question if HD fails on a strato 6gb
Just curious if a hard drive failed on a strato 6GB can it still be used as a player with Terra add on?
I asked this a month or so back and was told by a K employee here that it would not work. That the unit requires the hard drive to function.
The above answer is correct, unfortunately without the hard drive the Strato/Strato-S is a brick.
