Problems with Strato playback
DmitryB
I've been having issues with playing from Strato for a while. (I had a thread previously.) I have a brand new JVC NZ8 projector, Marantz AV Receiver. Have swapped out HDMIs multiple times. The problem does not go away.
First, I every time I power up the player/projector/AV Receiver - I get an "Out of Range" error. If I switch the Input to another player (Zappiti or Apple TV) and return to Kaleidescape, it tends to work all of a sudden.
Second, most of the time after I start playing a movie, within a few minutes the image will vanish, but the audio will keep going. If I switch to another input and return to K, it works again. And this time will play the movie through without a problem.
When I check the Vide Capabilities on the Strato, I get the below error message.
I don't know what to do at this point. Multiple HDMIs, new projector (the old one it turned out had a failed DD Board, but now the problem continues with a new projector), new AV Receiver. Same old Strato; at this point I have to conclude there's an issue with the Strato? Anybody have any ideas what the heck could be going on and why I have this error message on the Video Capabilities? And if this is why I may be getting "Out of Range" error? And why switching to a different input usually "fixes" the problem (albeit until the next time I turn the machine on?)
Are you running video through the receiver and then to projector? If so, have you tried bypassing the receiver and running video straight from Strato to the projector and using the Strato’s audio out to the receiver?
I ask because I have multiple setups and I’ve found that limiting the devices the video needs to pass-through, yields better results. The exception being a video processor, which I’ve not had issues running video through.
I have Strato => Marantz AVR => JVC Projector. I mean...there's theoretically no reason why this shouldn't be working... I can't imagine everyone is connected directly from K to Projector? I don't know if there could be anything in the settings of Strato OR the Marantz AVR to solve this problem. But somewhere communication fails and it shouldn't and I'm at my wit's end!
Right, it should work. I just think from a troubleshooting standpoint, if you don’t run into issues going straight to the projector, it might help isolate the component introducing the problem.
I have a Strato S and am having the same issue where the video will vanish on no matter what I play and the only way to fix it is a soft restart or a hard restart from the web UI…..Don’t know what’s causing it but since your having the issue I guess it’s a software bug ….I’m running it through a RZ50 to a QN90B…
Haven’t tried the switching inputs trick I will start doing that now for a faster solution but this needs to get fixed
However I’m not getting the out of range error when I power on….it’s powers on and displays normally but I get the Video cut out frequently and just checked and switching inputs corrects the issue just like your setup but something is definitely buggy with the HDCP Handshaking
This is an HDMI issue. You mention that you “tried multiple cables” - which ones? What lengths?
My Strato is connected to a Lumagen which then outputs to a JVC RS3000. For years I was using a Denon 8500, which owns Marantz. I have no issues. I am using Tributaries HDMI cables. Make sure they are 2m long. Longer or shorter may not work.
Ensure the cable is firmly seated - disconnect and reconnect it 3x to make sure.
Turn on sequence can also be important. Use Standby mode on the Strato (ie, make sure it’s never fully powered off). JVC should be turned on last.
So, I connected the Strato directly to the JVC Projector - and same problems. So it's not the Marantz. It's either the HDMI or something wrong with the Strato.
Surge, I've used a bunchy of different cables, including Uipro, Comprehensive. Some others I've since thrown out so can't name. The distance between JVC Projector and Strato/AVR is about 15 feet. That can't be helped. I guess my next step will be to go with Tributaries or Bullet Train HDMIs. (And if that still doesn't solve the issues, then it's a Strato problem...)
I'd be curious if switching Inputs works for you.
Switching inputs did work…so it’s def a HDCP handshaking issue with Strato S and the current Firmware….I actually just bought this unit used and am returning it and moving to a Strato C/ Terra combo ….Will keep u updated if I have the same symptoms using the same setup ….and I will be keeping the same hdmi cord just to be sure …
Interesting. @MikeKobb (I did just contact Support), but could anyone look into this?
If I don’t have the same symptoms when my StratoC/Terra combo comes with the same hdmi cord then it’ll be pretty definitive….They arrive Thursday
How do people feel about Bullet Train HDMIs? Someone is telling me Tributaries, Bullet Train or Gefen are the HDMIs to get. (Bullet Train is the easiest for me to find via B&H.)
If you've contacted support already, it will be escalated to engineering if necessary. It does sound like an HDMI interop issue.
Thanks Mike! I bought this Strato used and the warranty is expired. I was told if it doesn't work, I will just have to buy a new player. I guess there is no actual servicing of existing equipment?
If you have a hardware failure in the Strato and it's out of warranty, then I believe that's correct, although I think there is a trade-in allowance for the old component. It turns out to be logistically unmanageable to repair & return individual components, plus you'd then get back a component where anything that wasn't replaced is still old and potentially more prone to issues down the road.
What you're describing sounds more like an HDMI interop issue, though, and we certainly provide support in resolving issues of that type whether the component is in warranty or not.
If it's OOW, you currently have 3 options:
1. return it to K in exchange for a 50% discount off of the cost of a remanufactured Strato-S (if available).
2. trade back to K for a $500 Store credit
3. sell it for parts
The Strato to Strato Upgrade Promo that was available has expired, so currently only Premiere products can be upgraded to Strato/Terra.
