Power Button for KPlayer 300?
ejfiii
Guys, is there some hidden power button for the Kplayer 300 mini 1080p player? I have two I am bringing onto a system that are plugged in, the network light is lit meaning its connected to the network, It grabs an internal IP address yet the blue lights on the front are off and I can't reach them through the server setup?
Seems simple but I con't find a power switch or similar solution anywhere.
Thanks in advance.
I figured it out guys. Early 300s shipped in standby mode. I had to find an ir remote to turn it on to give it an ip address.
Thanks.
If you don't have an IR remote handy but you *do* have a laptop, you can connect to the player on port 10000 and send a control protocol command to tell it to leave standby. For example, on a Mac, you open a terminal window and on the command line enter (without the quotes):
'nc {ip.addr.of.player} 10000'
'01/1/LEAVE_STANDBY:'
