Hello All
I was wondering if someone would take the time to help me understand how to buy and set up a system for my client. I am a builder who has dabbled in a small amount of automation, and I am to install Kaleidescape into a large home that I am constructing. I have searched the forum but a lot of the answers are technical in nature and I am looking for basic information to begin with....
Is there someone that can answer the following?
I am using Sonos for sound throughout, which is hardwired with Cat 6 cable. I am using IP cameras with pan/tilt for CCTV. I have to select an intercom that will interface with house phones. I will control all blinds, lighting, cameras and theatre with an iPad, that I intend to both wall mount and have free, and have iphones that the client uses already as television remotes.
The Kaleidescape output is required for the theatre, bar, family room and two bedrooms. The house is a brick/concrete construction of approx 18,000 sq feet so I am not considering wireless links.
1. Can someone give me an equipment list? eg is a mini system suitable for this?
2. Do I need to separately hard wire each zone, or can I use the Cat 6 layout that I am to use with the Sonos?
3. If a separate zone, is a single Cat 6 enough?
4. How do the zones control remotely, ie do I need a repeater signal from a remote to the server or does the player in each zone do that?
5. I have yet to spec up a theatre projector and equipment list. Are there any recommendations in relation to the projector specs (eg I am looking at Sim2 Domino-60) that will affect the K output?
Thank you for any answers...
Cheers
J
Cheers
J
