Need advice: BluRay player
MattyDaddy76
Utah
I’d like to get everyone’s opinion/advice on this. I love my sV and the quality and convenience it brings and I have a PS5 with disk player already. But I keep coming across some titles that may be better/different/have other options like DTSX/Atmos/DV/HDR10 etc that I’d like to own that differ than what is available on Kscape.
I realize I can play any 4kuhd disk on the Ps5 (part of why I bought it) but the PS5 doesn’t play in Dolby vision. My 77” Panasonic OLED just looks better 99% of the in DV although I haven’t compared a like for like title in DV vs HDR10.
So my question is, especially with Panasonic Blu-ray player price increase and Sony discontinuing the X700, would it be worth just buying a Panasonic UB450 or UB820 for their current prices? Walmart has the dpub450-k for $298 locally I can pickup today. (Was only $238)
Is the Sony x700 the better option if I can find one? Again, local Walmarts here had a bunch.
Or do I just go for the Pana UB820 for the best deal I can find? (I don’t need the HcX processor since I have a Panasonic tv but that may not always be the case). I don’t plan on using it much and only have a handful of disks. But for example, I’d like to get World War Z in the best possible format and play it on the best possible format.
Basically what I’m asking is, should I get a blu ray player just to have one? And if yes, should I get the better one or just get one that works? (The magnetars and UB9000 are more than I want to spend and more than I need).
Thank you for any and all advice.
Try to grab a nice lightly used Sony 800 mk2. If that’s an issue then go with the brand new Panasonic 820.
Remember the X700 doesn’t support Dolby Vision.
Edit: the x700 does support DV, I believe the older versions came without DV and the feature had to be enabled via FW update.
You're on a TV so the Panasonic's HDR Optimizer (tone mapping) will provide a superior image. I see no reason to recommend a Sony over Panasonic unless price is an issue. Regarding the 820 vs. 9000 the major hardware differences are audio DAC (better in 9000) and overall build quality. If the disc player is in the room with you then I'd really recommend trying to grab a 9000 (even if used) as it's a quieter player. And, obviously, I highly recommend getting a modded player both for region-free and custom firmware options. (Panasonic's Asian firmware includes External Subtitles support which is ported in modded firmware.)
HOLY TUNA! I was just typing the URL for 220 Electronics into this post and thought I'd take look at what a region-free Pansonic UB9000 is currently going for... $2,000!!! Yeah, wow, ok. It's still my recommendation for most premium customers (short of Magnetar) but yowza...
Panasonic's HDR Optimizer is completely irrelevant in 2026. It's got limited options for what it can do, and the processing in its 2016-era SoC is worse than what any TV will do natively. If you buy the 820, turn HDR Optimizer off, it'll just hurt the image.
The difference between the 820 and the 450 is that the former uses Panasonic's proprietary first-party SoC and the 450 uses the same MediaTek MT8581 that every Chinese player (including Magnetar) uses. There are claims that the 820 has better video-processing or upscaling or whatever; I wouldn't put much faith in that, and even if it is true, it's going to be such a minor difference that it's not worth caring about if you're at all budget sensitive.
Get the 450.
(And no, the X700 is not a better option; it has an annoying quirk where it can't automatically switch into Dolby Vision, so you need to manually enable/disable it on a per-disc basis. The Panasonic player is preferable.)
Fwiw, I own a mini stockpile of spinners; Panasonic (2x9000/820), 2xSony 800m2, Reavon x200 and the Magnetar udp900 mkii (which also doubles up as my media player and handles all my rips).
The Sony has always been the dependable workhorse in my personal experience. I have in recent times, encountered some issues with certain labels on the Panasonic (KL and paramount in particular). I invariably end up switching over to another player to finish out the presentation. It’s not a regular feature, but slightly annoying when it happens. There is some point of reference when I recommend the Sony (without breaking the bank), If you can secure one somehow. And imho the Sony is arguably as (if not more) silent as the Panasonic..ymmv. But as rightly pointed out, the manual toggling to enable/disable Dolby vision is an irritant, in which case you might be better off with the Panasonic since it performs that task automatically.
All the players have their own unique quirks and strengths, but I would not put much emphasis on the HdR optimizer as a feature which is required in the current landscape. Maybe if you have a Jurassic display/pj which struggles with high nit content then you might have a case. But modern displays/ video processors are capable enough to handle the same.
I have an original X800. I finally updated to the latest firmware from what was in the box years ago. But it’s a persnickety lil bitch. Loved it prior.
Thanks for the info. This shows how long it's been since I had a player hooked up to a TV. I did a quick "Is this still worth it" search when writing my comment and "yes" came up for often than not. Likely recycled content from years past with new dates. I stand corrected. Thanks.
I have a modded Oppo 203 that will play any disc, but actually hasn’t been used for that purpose in years. I’m still buying discs, but instead backing them up to my Plex server and then playing those files in the theater. So my recommendation for your next disc player is an external 4K disc drive for your PC.
What did you mod? The firmware?
I picked up an open box - like new Panasonic 820 earlier this year from Best Buy for like $450. It's been just fine, I've always liked their players, but it doesn't get used much.
I also have a Magnetar player in for review right now which is a beast, even better build quality than the Oppo players were, and plays pretty much any type of disc you can find, though obviously a much different price point.
I have had a Panasonic 420 for few years now that has worked well.. Since I am using projector I do not need DV which the 420 lacks.
Its UI is beyond dated but gets the job done for the ever increasing # of favorites/titles I cannot get on K. I have given up on the whole ripping crap so its either K or disc for me going forward.
