Movie Scenes - Devotion
bogdandr
Hi,
Any idea when Scenes will be available for Devotion - 4K?
In general Scenes are implemented when the movie is available in the store or there are cases when K team add them later?
Thank you
I’ll find the way 😁!
Thank you!
(I’m beginner in K world 🫣)
How things are working regarding Scenes?
Is something K team develop and release together with the movie or they sometimes add later?
The scenes and scripts functionality was copied over from the Premiere systems. It is techni not supported on Strato/Terra but I have never had a problem with it on the Encore systems.
Download script to a,PC and then do a load script of that file using you Strato/Terra IP address: “192.168.x.xxx/scripts”. Some other helpful resource:
And my latest hits...:D
  • script_2_MIN_MOVING_BASS_ON_BEDS.dat
  • script_4_MIN_DTS_NEURAL-X.dat
  • script_11_MIN_TOPSMMERSION.dat
  • script_15_MIN_ATMOS_ENGULFMENT.dat
Works on Strato S
