I've submitted this to support and they are looking into it, but claim they haven't seen it before. Curious if this is truly isolated, so I'm asking here to see if anyone has seen this.
Basically, I've got an M300 player that's visible above my TV. So I have it set to "Off" for the front panel lights. Don't care to see it. I know it's there and I know it's on.
Every few weeks for the last few months, I go in the room and it's on, but pretty dim. I load the config page in a browser and it *says* Off. Hitting "OK" in an attempt to set it to OFF again doesn't do anything. If I change it to "1", it actually gets a bit brighter. Then I can change it to OFF and it goes off as it should.
But it only stays that way for a few weeks and then does this again. Can't find any rhyme or reason as to why. I did verify a couple times that "1" is brighter than this strange state. "2" gets even brighter, etc. The player works perfectly otherwise.
Anyone else seen this?
--Donnie
--Donnie
