Peter Nielsen
Hello,
As of recently my-kaleidescape/home is warning me "Player (1234 56789012): Network link is 100Base-TX. This component performs best with a 1000Base-T connection.". The warning is accurate. The switch that the M300 is connected to also reports a link speed of 100 instead of 1000.
The player has worked fine in 1000 mode until recently. This problem has appeared within the past few months for no reason. I've tried to replace the switch (Cisco SG100-08) without any difference. I also tried to plug the player directly into my Cisco router and force the speed to 1000. No go. Only 100 works.
As a last resort, I ordered a Netgear GS108Ev3 Managed switch. It did not work any better, but this switch has built-in cable analyzer software. The software claims that my M300 has a shorted Ethernet cable. I've tried switching out the cables, but the short always remains at the length of the cable, indicating the short is at or inside the M300. I've carefully inspected the M300 RJ-45 jack, but it looks good.
So... what could be wrong? Netgear GS108Ev3 cable analyzer tells about a short at the Kaledescape end of the cable. If I try a longer cable, the distance reported will be longer, so it's pretty clear the short is at the M300. I'm thinking it must be the RJ-45 jack that is bad, or the Ethernet transformer.
Does anyone know more about the Ethernet jack in the M300. Is it a jack with integrated magnetics, or is the Ethernet transformer a separate component?
My M300 is out of warranty, so the only options Kaleidescape is giving me is to purchase either a remanufactured or new player....
Thanks,
Peter
Thanks,
Peter
