M300 Fan Noise
BrianK
Hello Again
I have a few M300 players in various bedrooms - whether powered on or off with the remote - they all have noticable fan noise and seem to be very hot to the touch (rear rhs) This doesnt seem like a very good product design - are other people noticing the same thing - even hanging them on the back of the tvs doesnt really disguise the noise. - Any suggestions:)
B
Dear BrianK,
I have same problems with the 1080p-Player. The support could not help. K told me, that the M-Class has another product design and fan technology. I seems that the problems are the same here. I opened a thread some months ago in this forum.
I use a socket from Intertechno. If I press the power button on my remote first the player switches off and than the socket. So the fan has no more chance to make noise. Not a good solution but it works.
K is not a green company. This is in my opinion the only negative point.
Best,
Patrick
Hi Patrick
Thanks for the advice - i read your thread - exactly as my experience - these things should be silent - poor design - really doesnt work in a quiet bedroom situation - i will try your power off solution - I have three - all M300 all noisy - despite good ventilation in a cool house.
The M300 is not a good idea if u are a light sleeper or easily annoyed by fan noise in the bedroom :)
Hi Patrick
That's interesting, I've got two and both are silent.
While designing the M-Class players, we set out to find a chip that can decode 1080p and lossless audio, drive our 1080p user interface, play a Blu-ray movie while simultaneously importing one from the tray (M500) and one from the connected disc vault, and start up so quickly that you can have a movie playing in under 10 seconds after pressing the power button.
We found a great chip that does all of these things – but it did have one small limitation. It does not provide features to achieve fast exit from a low-power standby. i.e. it can’t go to sleep deeply enough to save a lot of power while being awake enough to spot a wake-up event. So the M300 Player draws 20 W while in standby. This 20 W load also creates heat - 68 BTU/hr. This heat needs to be exhausted (hence the fan).
One might compare the M300 Player’s power consumption and standby state to a device like AppleTV. But the AppleTV doesn’t do the things I listed above – it can’t decode 1080p or lossless audio, drive a 1080p user interface, or even play Blu-ray movies. As a result, they use a less powerful chip that draws less power and requires less cooling.
Keeping the chip cool with a fan also makes the player more reliable. We use extremely reliable speed-controlled fans with vapo-bearings that are the quietest available. If the player has good airflow and the room is climate controlled, there is very little noise. If the room is below 25C (intake air temp) and all air vents are un-blocked, and you are more than 6 feet away, you should not be able to hear the noise from an M300 Player.
Tom Barnett
Kaleidescape, Inc.
Thanks for taking the time to respond Tom - Its great to see a company so keen to provide information and support.
I have found a very simple way to solve the problem in my home - using a remote power-off product from Eon - simply turn off tv with remote - powers off M300 30 secs later
Works perfectly problem solved
Appreciate all the support
Brian
Thanks Tom.:)
