bernard301
Hi everyone, I'm new to the Kaleidescape environment and coming into it with second hand equipment!
I recently (in the last couple of week)purchased a setup second hand on eBay and was delivered the equipment. The equipment purchased was a KServer-1500, D700 Disc Vault and 2x M300 players
On setting up the server, drive bay number 4 did not appear seated correctly and so I removed the drive, checked it was not damaged and reinserted it. This has obviously initiated a drive rebuild. The system then works fine until the server rebuild hits approximately 12-13% when the server crashes and loses network connection with the remaining devices.
Up until the rebuild crashes, there appears to be full functionality of the devices, however it will obviously not add anything to the library until it is rebuilt.
Once the rebuild has hit 12-13% the server flashes amber and blue, with network connection lights on the LAN port working, indicating a DHCP fault. I have tried reserved addresses as well as static ip’s on 2 different modem routers however the issue remains which leads me to believe that this is a power supply or other hardware issue. I've attached the system log below!
The bay seller is working with me to troubleshoot but what are all of your thoughts on the issue
Thanks in advance!
Thanks in advance!
