I have just started to experiment with the Kaleidescape Web Tablet which allows you to control the system from your PC. Right now I am just using it to select music albums to play through my whole-house audio system. When I run the program, it works great and allows me to choose the albums I want to play. However after I choose the albums and click the play button, I can't find an easy way to exit from the application (it takes up the entire screen). The only way I can find is to go into the Windows Task Manager and chose end task. The music does keep playing after the program is exited(which is good). I must be missing something easy. Can anyone provide some assistance or direct me to documentation on this application that might assist me?
Thank you.
Scott
Thank you.
Scott
