There are power options in the system already. Here is some information from the AMX interface:
Movie Player (KPLAYER-2000, KPLAYER-2500) Power Control
These Movie Players cannot be powered‐on over a TCP/IP connection. When these Movie Players are turned off, the Ethernet Port shuts down and they cannot receive any TCP/IP communications. Movie Players connected directly to the controller via the RS‐232 Control Port can be powered on remotely.
Using Command Routing, it?s possible to make a serial connection to one Player and issue commands that route to a second Player. Those routed commands travel over the network to the second Player. If the second Player is powered off in this scenario, power‐on commands routed through the first Player will not power on the second Player.
In some situations, this limitation is not an issue. The Player remembers its power state, and resumes its last power state after a power outage. For example, if the Player is on when the power is lost, the Player automatically powers back on when the power is restored. Additionally, the Player is very quiet (not completely silent ? the fan runs as needed) and the noise is usually not noticeable when the Player is in a cabinet. In many installations, the Player is left powered‐on continuously.
If you must power cycle the Player from the AMX controller, you have two options:
► Use RS‐232 control without Command Routing (cable directly connected to the Player).
► Use an infrared (IR) emitter to send the IR Power On command, but use TCP/IP for all other commands.
Power Control for All Other Kaleidescape Players
The Network port of Kaleidescape Players, other than the KPLAYER‐2000 and KPLAYER‐2500, is powered while it is in standby?but in a limited mode.
If you send the Power Off command to the Player over TCP/IP, initially there is no response. After a moment, the network connection drops, and is then re‐established. The Player is now in limited mode and responds only to the Power On command. When a Power On command is received, the Player powers on. The network connection drops momentarily and then reconnects. The Player is now ready to respond to commands normally. You cannot use Command Routing to power‐on a Player. When using TCP/IP, you must make a direct connection to the Player to turn it on.
So if you follow these procedures and power down the device and the drives have stopped you could then put the AC on a relay and turn off all power.
Gary
