By any chance do any Kaleidescape system owners here have a Krell Foundation 7.1? Why I ask is I have a bit of a whacky audio issue with my M700 and the Krell has something to do with it.
I listen to music via the M700 analog audio outputs connected directly to my Halcro dm8 preamp. I only use the Krell when watching movies; it's connected to the M700 via HDMI. The M700 audio preferences are set to bitstream output.
Ordinarily when I listen to music the Krell remains in standby...it's not in the signal path because the M700 analog output to the pre-amp bypasses the Krell completely. However in this configuration the M700 plays music about 10% slower than the correct speed, the cadence is obviously wrong and the pitch is noticeably lower (like in the old days if you had a battery operated cassette deck, when the batteries start to go flat the tape slows down and the pitch lowers). This is what I'm hearing with my M700.
If I turn the Krell on, about 3 seconds later the cadence and pitch of the music returns to normal. I can put the Krell back to standby and playback remains normal. So at the moment my music sounds like it is coming from a cassette deck with flat batteries, until I cycle the Krell on and off. This behavior was evident in kOS 5.3.0 and 5.2.x. Prior to the Krell I had an Integra DHC 80.3 hooked up in exactly the same way and music playback was always normal. The behavior is repeatable with different CD content.
