How do TV series appear on the wall.
Let’s get that fixed on the enhancements queue.
Good luck.
Good luck.
I like them shown individually. It is way too many clicks to go into a single tile and navigate to the episode you want to watch.
I was thinking main wall shows the series name, click once and you see the 3-whatever boxes for each season. And each season has the all the episodes listed.
That’s probably too much work from the programming side of things. Also, they might be running out of gates/memory on the Strato‘s FPGA. They used to have the screen saver with animations. Now it is a static image of their logo floating around randomly. This likely was a decision to free up some FPGA space for other functions.
Mike Kobb layed out the reasons why this likely hasn’t been done yet in the thread I linked. It is a non-trivial amount of software work because it would require database changes that would ripple through all of the downstream products.
Also, are you sure the strato is using an FPGA?
Some System on a Chip (SoC) or flash based FPGA. SoC is more likely but the same memory and processing power limitation apply. Strato is a several year old design now.
