Hi,
I just purchased a Strato 10TB here off the forum. I hooked up the ethernet, plugged it in and turned it on by pushing front panel button.
When I went into the browser interface I went under Components and then Add Component.
It listed the new 10TB server and I clicked OK to add.
When I go back to the components screen at the top it now says 2 Movie Players with storage, but how do I see the other Strato? It just shows my original 6TB Strato.
Thanks
Sean
Thanks
Sean
