HDR UHD store movies
bogdandr
Hi, about HDR and UHD movies from the movie store.
Using a Strato S.
I bought the option HDR+UHD but it shows only HDR. While other movies/videos have UHD marked.
What is the point? Will 4K HDR include UHD?
When you purchase titles in 4K, you will get both the HDR and UHD versions IF both are available. Some titles have both others have one or the other.
When you download a title, the default is to download the highest quality. So HDR if both HDR and UHD are available. If you want both downloaded, you will need manually pick both when downloading.
Also, as a reminder to new owners:
HDR = HDR2020 w/4K resolution
UHD = SDR709 w/4K resolution
