Does the Strato C have a fan?
Gui0312
I hear my Terra pretty loud, what sounds to be a fan but the Strato is pretty quiet, does get hot though. It’s very well ventilated just sitting on a piece of furniture close to an AC vent.
It does have a fan, but it's designed to use the aluminum case as a heat sink, and the fan will only come on if temperature is excessively high. You can see the current temperature on your system's browser interface, and that display will show you where the player's temperature is within the normal range.Screen Shot 2022-07-31 at 1.58.28 PM.png
