I just received my M700 Disc Vault and can not for the life of me get it to connect to my computer or to the server. The server and the vault are on the same gigabit switch. I've checked the cables which are fine. The yellow light on the ethernet port of the M700 is lit and the green light flickers showing connection. I can ping the M700 from my router's software and it shows the M700 to be "alive". I can connect to the server just fine from my computer and it is set up and functioning properly.
However, I continue to get the error message "Unable to communicate with server. Vault IP address: 192. ...". I can't connect to the M700 by any means: http://my-kaleidescape.local or using IP address or by using serial number. I am confident enough in my networking skills to realize that should not be an issue.
I think it is a problem with this particular unit. It is a long weekend here, so my dealer will not be able to talk to K. until Tuesday. Has anyone any suggestions or experience they can share?
Thank you.
Wayne
Thank you.
Wayne
