californian56
Good Morning. I was looking for a little help with my system control, which is a Crestron (CP2e). I use Crestron's Mobile Pro G iPad App as a control panel. I have an original 5U Server, K2500 Player and KReader. Up until recently all was good and working exactly as my dealer configured it several years ago.
Then my reader started to fail. So, dyc1077 was kind enough to sell me one of his K5000 Player/Readers to replace my Kreader and K2500 Player. Everything went flawless with dyc1077 and his unit works perfectly. Thanks David.
My problem is that once the the K5000 was installed and configured EXACTLY as the K2500 was, I cannot control it via my Crestron App. It all boots up Blue and the Kaliedescape screen saver displays on my screen but that's it. I confirmed the the K5000 imports and works perfectly with the remote control built into the Kaleidescape App, just not with my Crestron. If I hook the old K2500 up and use the K5000 as just a reader all is good again.
My question is. Are the Crestron serial RS232 control codes different for the K5000 vs. the K2500?
Any help would be appreciated. Just thought I'd ask here before I reach out for my dealer in case it was something simple I was missing.
Thanks,
Richard
Thanks,
Richard
