Hey guys,
I saw that someone else might have had the same issue but with different equipment. I'm starting a new thread hoping that an expert might be able to help me resolve this problem.
I am currently running a Bomaker polaris 4k projector, connecting via eArc to my Nakamichi dragon speaker system, and connecting the Kaleidescpe costar directly into the Nakamichi dragon speaker system.
Prior to the Nakamichi dragon speaker system instalation, I had the Costar connecting directly to the Polaris and the rendering of the premiere source and switching seems to be perfectly fine. Both the Premiere SD, HD content plays well and the Stratos content UHD and HDR plays perfectly. When retrying this post my connection to the Nakamichi dragon, it seems to work fine as well.
The issue is: When I connect the Costar to the Nakamichi dragon system, the Stratos content UHD and HDR plays perfectly on the projector and sound is amazing, however, all the Premiere source content when the costar makes the switch no longer works. I get a staticky screen, and the rendering output according to my projector is DVI 1920x1080@60hz (see attached pic)
I've tested changing all of my HDMI connections to 2.1 enabled cables, and the only way that it seems to momentary work is when I disconnect the costar HDMI cable and reconnect it back into the nakamichi dragon, at that point the Premiere content seems to be back and working in all it's splendor. If i stop the play (for the costar to go back to the kaleidescape UI) and resume play or play any other premiere sourced content, the staticky screen resumes unless I again, disconnect the HDMI cable and reconnect it.
Does anyone have any idea how to potentially resolve this? I am at a loss on what to do and would love to get some advice.
Thanks so much in advance!
Mike
Mike
