Can compact Terras be safely stacked or should there be airflow between them?
The Compact Terra Prime (and original Compact Terra) are designed to have airflow moving from front to rear. You can safely stack them. You should ensure, though, that there is a minimum of 2.5 cms (1") clear space in front of the server and 5 cms (2") of clear space at the rear of the server.
You can also safely mount two Compact Terra Primes (or a Compact Terra Prime and a Strato C player) side-by-side in 1U of rack space. We have a mount available specifically for that.
