Just received my Modular Disc Vault today. Awesome!!!
Loaded all of my discs into the Vault and had problems with two of them which appeared as "Unrecognized."
1) Bolt Blu-ray. Vault would not recognize the disc. I ejected it and then put it in the M500 and imported it that way. Only took 47 minutes. Haven't reloaded it into the Vault yet, but hopefully it will recorgnize it and then be able to play like normal.
2) Memento Blu-ray. Vault would not recognize the disc. I ejected it and then put it in the M500. M500 held it for a couple of seconds, then blinked amber and then ejected the disc and the import screen on the Web browser says, "Logical Volume Id" I tried it again and it did the same thing, this time saying "Logical Id2" I checked the disc and it is totally flawless looking. Wondering if there are any other issues reported with this disc or what "Logical Volume Id" means...?
Thanks!
John Sciacca
Thanks!
John Sciacca
