BEST ATMOS YEAREND 2023 EDITION
NEW Kscape user trying to import this file and keep getting this error.. "
This file does not seem to be a list of scenes that was exported from a Kaleidescape System.
Select the file from which you wish to import scenes. You will still get to choose which scenes you want to import from that file."
I tried a couple different files and renaming this file with no luck. Any ideas what is wrong or what I am doing wrong?
Thanks.
Try “Server IP Address/scripts”
Super-wierd indeed. The focus of these scripts is on Atmos around the head wraparounds, topsmmersion, and side-to-side ping pong effects. Beau is a prime example of the first category, Meg 2 exemplifies the second, and Black Widow along with Goosebumps are key examples of the third category. These are all categorized as rich in proximity effects, identified after examining content valued at approximately $85,000.
I’ve downloaded many of the scripts, what a great feature! And a big thank you to those folks that put them together for us.
Guess I’ll have to download a few more movies now!
If I add one of the movies in the script later will it go out and add those scenes automatically?
I've used a number of Peter's (Cineramax's) scripts and modified as necessary. I have one called "Movies - Bass"; one called "Movies - 3D" and one call "Music" (from movies for the most part).
The "Movies - 3D" script will prove, without a doubt, that great Atmos speakers (great power handling and extension) are not optional if you expect the best 3D envelopment.
I downloaded the script "YearEnd 2023" and while I have most of the movies, the scenes described in the scripts are not there. How do I add those custom scenes?
Did you import the script? If not, when you do import all the scenes from movies you have will be marked automatically. If you have imported, then it could be that some of the titles have been updated since the original script was released.
I did import the noted script. So it must be that ALL of the titles were updated because none of the custom scenes show up. Would be nice if, when updating a movie, K would save and then re-add those custom scenes - but I'm sure that won't happen.
