A component in this system has a 100Base-TX network link. The component performs best with a 1000Base-T connection.
soGM
This is new, and any idea how to change to 1000Base-T connection as Kaleidscape advises?
thanks
It auto-senses the network connection (i.e., it’s not a setting). Try a different port on your switch/router or a different network cable.
Good luck,
Or rebooting the device & swapping the cable - I have occasionally got this on my network on a component and this fixed the problem.
Good luck,
Thank you very much, switched port and cable. All is well.
Thanks very much, switched port and cable. All is well. Glad I asked here.
