Struggling to access system
Drewnation
Afternoon everyone
I have three Kaleiedescape pieces outlined in the attached doc. All can be pinged (except the 172 address) but can't access any interface on any of the units. I've tried the support docs and can't seem to get anything to work. The vault and 500 player at both glowing steady amber light. Any ideas?
thank-you.
Mark H
Maybe you missed the attachment?
If the devices are glowing amber then there is a network issue and they are not seeing the server. From a browser you can (as far as I know) only access the devices via the server browser interface i.e. by connecting to the server ip address and viewing via the 'Components' tab.
Have you tried to see the devices?
Try powering off and re-booting your network devices and your server (you don't mention if it is glowing amber or blue) , it may clear the problem but that is where I would start
J.Green
Kaleidescape, Inc.
Based on your screenshot, there is no server present on your network (which would explain why all of your devices have amber front panel lights).
I would start by verifying that your server is up and running, the network cable is properly connected, and troubleshooting your network.
Deleted above because John and I answered same time.
AlienWarlock
Your server is not showing up. Did you reboot it? You should reboot your router as well because it looks like your components might be having trouble getting IP addresses from DHCP. Also has your system been offline for a long time? Your version numbers look (6.0.1) look pretty low. They should be 8.6.0 or 8.5.1 if your system has been online up until now.
Drewnation
System has been offline for over a year, which piece is considered the server as I don't think I have that. Only the m500 player and the vault. Assuming I need the server piece, which models are considered servers for this line of product ? I live in a Toronto area and would be interested in acquiring.
As previously pointed out, you do not have a Server showing in that capture. You have the following:
M300 Player: This is an M-Class Player. It can ONLY playback content, and that content has to come from one of the Premiere servers.
M500 Player: This is also only a Player, but unlike the M300 it has an optical drive used for importing content to a Server from a physical disc, and can also act as a standard DVD/Blu-ray player by playing back physical discs.
M700: This is a Vault that also has a built-in Player. It is used to import physical discs to a Server, and in the case of Blu-ray discs it also stores the disc in the Vault to meet the requirement that a Blu-ray disc must be "present" during playback of content on the Server. The internal Player acts just like the M300 noted above.
You are missing a Premiere Server. The Servers usually used with the above Players is either a 1U (K1500), 1U+ (K1550), 3U (K5000), or 5U (K2000, and 2500). You need one of those to complete the system.
Drewnation
Thank-you Jim, I will see what I can find. Appreciate all the information everyone.
Sorry, to answer you last question directly, you need one of the following:
1U (K1500) Server: These are no longer sold by Kaleidescape, you would need to find one used. You should however consider that the 1U is no longer supported by Kaleidescape for repairs or replacement. You cannot even get a replacement power supply from K for this server, so basically you are on your own if it fails. You can get replacement drives, but that's it.
1U+ (K1550) Server: This is the newest Premiere Server in K's product line. They are available new from K, but are expensive.
3U (K5000) Server: This is the largest Server in the Premiere line. It is no longer sold by K so you would need to by used. With exception to drives, replacement power supply, and a few aesthetic parts, there is no support from K on this product.
5U Server: It would work, and their cheap these days, but it's the original server, very old, and no longer supported at all.
Hope that helps.
