Strato Subtitle Shift
Noah Winter
Well, I have my new Strato up and running and it is very exciting. My first movie was the Northman which is a 2.00 Aspect ratio movie. When they were speaking in their native language and subtitles were required, the bottom line of dialog was cut off. My Oppo 203 has an option called "Subtitle Shift" that allows the subtitles to be raised or lowered. I did not see where this was an option with the Strato. The alternative would be to drop back to 16:9 and have the black bars on the top and bottom. I opted to stay with the 2:35 aspect ratio to use the whole screen as I think I got the gist of the missing dialog (they were usually very angry).
If it is not an option yet I think the ability to move the subtitles to customize for your theater in such a high-end system would be a useful feature to have.
Thank you,
--max
I'm not in front of it right now so don't remember where the option is, but there's definitely an option to keep subtitles on the actual image and not outside the frame. Not as good as moving them up to your desired location like with the Oppo, but will put them all on the screen nonetheless.
Oh, that would be fine. Maybe it’s on the OSD?
I’m not in front of my Strato, but yes you access it from the OSD. The setting is called something like “Reposition subtitles…”.
