Strato C IR in cable
dlaunde
Quick question: For the IR In port, does the 3.5mm cable need to be mono (tip + sleeve) or will a more common stereo (tip + ring + sleeve) cable work just fine?
I have a mono in there. Can you share if stereo will work too...for later people that may search this?
I actually can't comment as neither is working for my specific setup. I am using a Logitech Harmony Hub sending out IR to an IR repeater, which is working with a bunch of small IR sensors in my rack. But for whatever reason cannot get the direct IR cable connection to the Strato C to work, so going to just use an IR sensor on the front.
Reach out to Kaleidescape directly. I use an IR mono cable and it works perfectly.
