Spears & Munsil UHD HDR Benchmark
SJHT
I know K normally deals with major studios, but it would be great if this was offered for sale on the store. Has this ever been considered? Seems like they would get a new stream of revenue as there are many folks that no longer use discs and would use the Strato for the best results. Maybe a win win! SJ
KDeering
I talked to Stacey about it and it can't be offered due to the way it is encoded unfortunately. I suppose they could license the montage and a few patterns, but it wouldn't be the same as the standard disc at all.
SJHT
That would be great. I really wish the store had some type of audio sync material so we could adjust 4K60 and 4K24 directly from a Strato. How hard can that be to add. SJ
