Premiere System - D2D question
Substance
I have only imported a few titles but it seems like I am offered D2D after a complete import from my DV700s. There are titles I don’t want to import but I want D2D. Is there a way to D2D before complete import? I have 3x DV700s and a M700. I guess I could remove one of the DV700s from the premiere system and add it to my Strato temporarily? Strato doesn’t import or play but give me D2D after a few minutes of inserting discs.
Also, is there a way to have my Co-Start’ed Premiere/Strato system download movies from the store simultaneously?
Without a disc tray, moving the vault to be a server is about your only option for no-import offers.
Maybe, but it wouldn't be pretty. If you have a premier server that you can remove from the pairing, then you can register it with the store as a separate system, which may allow for simultaneous targeting (not sure how well the download speed restrictions would play in this setup... kind of wishing I had done some more playing with it the last time I had separated things.)
Yes I’d recommend connecting one vault to your strato. This will allow mass cataloging without needing the full import.
The only other way that I know to “quickly” catalog is to use an M500 on Premiere, but that isn’t an option here.
I did move one of the vaults to Strato. I cataloged Doctor Sleep but it won’t give me D2D. Is this a glitch with this title?
Not sure about this title but not every title is available for D2D
Doctor Sleep has the verbiage that says “D2D is available for this title” on the store. This is why I thought it might be a bug.
