P90X DVDs Will Not Import
Joe
I just purchased the P90X DVD series and put them into the M700 to import. Unfortunately, 11 of the 13 discs failed to import with this error "DVD cannot be imported". Anyone else run into this? Not having P90X on the k-scape would be a MAJOR bummer.
I am having the same problem with P90X3. I assume there's some extra level of protection on these disks? Any ideas or am I out of luck?
Hmm. Wife's Original P90X ( I assume, was not aware of a 2 or 3) imported fine through our new C1.
Kevin D.
I've had similar issues importing some DVD sets in my M700. I put them into my KMUSIC-4000 one at a time and it imported them into my system just fine.
I thought it was possibly just a format that the M700 didnt support, which seemed a bit strange to me.
