jtonthebike
Hi All,
I am looking at used Kaleidescape kits on both here and other places, I wondered if someone could offer some thoughts.
So let's say I choose a server + a player, the player located near my plasma panel so I can just run HDMI and the server with all the other kit. Here's a few questions:
What network connection type is required between server + player and does it need to be on it's own (V)LAN?
I can see that should drives fail, I can purchase replacements from K'scape but do these disks contain the OS or just the film/music data?
If just the media data and the internal disk dies, how do I replace that? (former sysadmin and worried about disk failure and not being able to boot the damned thing)
Are using third-party disks acceptable? I would suspect they're not supported but are the drives SATA or another format?
There's an old server listed on ebay without hard disks and not booting, i suspect it's a PSU issue, if it isn't, can K'scape send me the parts needed to repair it should I wish or do I have to send it to them?
many thanks in advance,
JT
JT
