jt_M3
Hello. I am reaching out to the community hoping someone might be able to replicate or has a fix for the problem I am experiencing. I recently upgraded my system to include a Kscape Encore server and Strato C player as well as the new Marantz AV10 processor. Since I also have a Kscape Premier system, I also added a Co-Star to "pair" the two systems. The issue is as follows:
I can see my complete movie catalog on the "paired" interface. I can play any UHD or HDR contact on my Strato with no problem. However, when I play any title from my Premiere system such as a DVD or Blu-ray, I only see video. The audio is missing. This is confirmed by the AV10 which reports it as unknown. It doesn't matter which title I play, the audio problem persists. If I stop the video, and then select a UHD or HDR title from the Strato unit, it plays as expected. Again the issue is with the audio playback on from the Premier hardware only. At the moment, it is paired to my M500.
I believe I have isolated the issue with the Co-star and Marantz AV10 combination.
Trouble shooting thus far:
- I have both a fully functional M500 and M300 player. I have paired both with the Strato and Costar, and the exact same issue is experienced.
- In the M500 Audio settings, it is set to Bitstream pass-through. I also tried setting it to player decode, and the issue is still present.
- If I swap the HDMI inputs on the Co-star between the Strato C and M500, the problem follows the M500.
- All HDMI cables are the same length and type/model and were just purchased new. I also tried older cables, and issue still persists.
- If I bypass the Co-Star completely and plug the M500 or M300 it into a HDMI port on the AV10, it works perfectly. Even with Bitstream Pass-Through selected.
- The Marantz AV10 has the latest firmware installed.
- Kscape support advised to try my old processor which was a Marantz AV8003. Since it is no longer installed in my rack, I did take the Costar HDMI output and feed it to the AV8003. Without any amplifiers installed on the AV8003, I was able to confirm the audio was being decoded from both the Premiere and Encore system via Costar.
