New Disk set problem
flitebynite
I bought a new (to me) Disk set for my 3U Server and I'm having a problem.
There are 13 1TB Drives. They all come to a solid blue light status except the hot spare that blinks blue. This seems like a normal status for a set of disks. Right?
The problem is, my M700 now says it can't communicate with the Server and there's a network problem. It displays a message to go to the browser interface http:// 10.10.18.123. This looks like a static IP to me.
The Server these disks are installed in is my existing Server that I've had for some time now.
My Server is set to DHCP and I can normally access it through the Browser interface. However, with this new disk set installed, I can't get to my server through the Browser interface any more.
Why would the Disk set cause my Server to change it's IP address from DHCP to a static IP?
I can put my old set of drives back in the server and everything works fine.
Anyone see this before?
I'm continuing to troubleshoot, but any suggestions or insight would be greatly appreciated.
Thanks,
Chris
As far as I know, there is no storage on the server itself and everything including OS & settings are stored on the disks. The disk set you bought are probably from a server that had static IP setup.
You will have to reset the static ip to DHCP on server with the new disks installed. This would be my guess.
@20hertz is correct. When you replaced your old drives with a complete set of new drives, you essentially created a new system. It's likely that the drives weren't reset before you received them so whatever configuration was on them before is your configuration now.
You'll need to set your server back to DHCP as well as restore any other configuration settings you had set up. You can reset the 3U server back to DHCP either by connecting a serial cable to the DB9 port on the back of the server or by setting up your PC to have a static IP on the same IP range as the server's current configuration (10.10.18.124) and then connecting the PC and the 3U server together with an ethernet cable.
Instructions for resetting the IP address via a serial cable are here: https://support.kaleidescape.com/Ws...he-serial-port-of-a-Premiere-system-component
The M700 is still looking for your "old" system so you'll have to group it to your "new" system once you've reset the network settings.
Additionally, if you had previously activated your Premiere system on the store, you will find that your "new" system is deactivated (or worse, still activated on someone else's account) and you'll have to activate it. If you still have your old disk set available, I'd advise you to put the old disk set back into the server chassis and deactivate your "old" system before activating your "new" one but that's not strictly necessary unless you already have 5 separate systems activated on your store account.
Thanks.
I was thinking the same thing.
I'm hoping I don't need to take the Server out of the rack and connect directly to it with my Laptop to reset it.
Thanks John.
As always, your detailed responses are always appreciated.
Chris
I configured my old Windows XP Laptop to the Static IP configuration and I now have access to the Browser interface.
However, there is a password protecting the entry.
Does anyone know how I can get passed this?
I've sent a message to the previous owner, but I've gotten no response yet.
Again, any help or insight would be greatly appreciated.
Thanks,
Chris
Chris, unless something has changed in the software that I'm not aware of, you will need that password from the previous owner (assuming they have it), OR you will need help from K Support (I believe they can reset on their end).
Support can reset that password for you. However, they are shut down for US Thanksgiving until Monday.
If you PM me the serial number of your server -- and you have it up and running -- I can remotely reset the passcode for you.
Thank you!
I'll send the info shortly.
I need to get around to the back of the Server and get the SN.
Chris
Very nice of you John, that's awesome!
I’ve had my system now for quite a few years and my family has been so happy that we have expanded to a couple of systems. The service that Kaleidescape gives is nothing short of phenomenal. That being said, this takes the cake. Working on Thanksgiving so that one of your customers can have the holiday be just that much better and special really blows me away. Thank you John and the rest of the team. I know it didn’t take you much time, but acts like that mean the world to the rest of us. Happy Thanksgiving everyone.
I agree!
Aw shucks guys. That's kind of you. I should confess that I'm not really being that heroic. I'm in the Canadian office. It's a regular workday for us here.
But I appreciate the sentiment.
Still very good of you to help Chris so quickly!! (He's a great guy!)
