Need screw size for bottom of Strato that attaches rack mount kit
iansilv
Anyone know the size of these screws?:
I do! I do! :)
It's an M3 x 10mm Phillips flat head stainless steel machine screw.
Full specs from our BOM:
Type: Machine Screw
Diameter: M3
Length: 10mm
Thread Size: 0.5
Drive: Phillips
Head: Flat
Material: Stainless Steel
Finish: None
Mech Standard: DIN 965
Other Standard: RoHS Compliant, UNSPSC 31161504
Nice! Should be easy enough to find at your local hardware store I would assume. That or a proper computer/networking/electronics supply store.
I have found that the local Ace hardware has a surprisingly good assortment of hardware including little metric screws like this. It might be worth a visit if you have one near by.
