I'm sure some folks have already seen these codes, but I decided to create this thread to make them easier to find.
The following explains the meaning of codes displayed on the front panel LCD of of the Vault when the vault gets into an unrecoverable error state. During such state the LCD will show the message "Error N; Press OK to restart", where N is a number documented below.
Notes:
NOTE: Contact your Kaleidescape Dealer or Support if the error code displayed on the front panel is not listed above.
M700 AND DV700 DISC VAULT ERROR CODES
DescriptionThe following explains the meaning of codes displayed on the front panel LCD of of the Vault when the vault gets into an unrecoverable error state. During such state the LCD will show the message "Error N; Press OK to restart", where N is a number documented below.
Notes:
- Unrecoverable error, in this context, means an error condition such that KEAOS is unable to continue to perform the vault functions of the device during the current boot; player functionality is typically unaffected.
- Vault functions include insertion and ejection of discs, controlling the internal optical drive and the carousel, disc identification and import, internal disc drive injection and ejection and providing disc presence information.
- The vault may or may not be able to recover from an "unrecoverable error" state after a reboot. Regardless, a reboot (preferably by power cycling) is usually the first recommended step when a user experiences an "unrecoverable" vault error for the first time on a given Vesta unit.
Error code | Name | Possible causes | Suggested action |
3 | INVALID_DISC_SLOT_INDEX | Software | Contact your Kaleidescape Dealer or Support |
23 | UNEXPECTED_MEDIA_ON_MOVE_TO_UNLOAD | Software | Contact your Kaleidescape Dealer or Support |
28 | FAILED_TO_SEE_NO_MEDIA_AFTER_EJECT | drive; hardware | Power cycle; Contact your Kaleidescape Dealer or Support |
29 | UNEXPECTED_SLOT_STATE | hardware; Software | Power cycle; Contact your Kaleidescape Dealer or Support |
32 | WAIT_TIMEOUT | hardware | Power cycle; Contact your Kaleidescape Dealer or Support |
39 | OPERATION_ABORTED | hardware | Power cycle; Contact your Kaleidescape Dealer or Support |
42 | OPERATION_FAILED | hardware | Power cycle; Contact your Kaleidescape Dealer or Support |
45 | OPEN_FAILED | hardware | Power cycle; Contact your Kaleidescape Dealer or Support |
69 | CAROUSEL_JAM_DETECTED | hardware; misuse | Clear obstruction; Power cycle; Contact your Kaleidescape Dealer or Support |
74 | CAROUSEL_BLOCKAGE_DETECTED | hardware; misuse | Clear obstruction; Power cycle; Contact your Kaleidescape Dealer or Support |
75 | OVERTILT_CONDITION | dynamic or static acceleration; hardware | Place Vault on stable and level surface; Power cycle; Contact your Kaleidescape Dealer or Support |
78 | SLOT_NOT_EMPTY | hardware; misuse | Power cycle; Contact your Kaleidescape Dealer or Support |
81 | NO_DISC_DETECTED | hardware; misuse | Power cycle; Contact your Kaleidescape Dealer or Support |
86 | OPERATION_NOT_ACTIVE | hardware; | Power cycle; Contact your Kaleidescape Dealer or Support; Contact your Kaleidescape Dealer or Support |
87 | REQUIRES_USER_ACTION | hardware; misuse | Clear obstruction; Power cycle; Contact your Kaleidescape Dealer or Support |
88 | FAILED_TO_CLEAR_BLOCKAGE | hardware; misuse | Clear obstruction; Power cycle; Contact your Kaleidescape Dealer or Support |
91 | MOVE_TO_SLOT_FAILED | hardware | Power cycle; Contact your Kaleidescape Dealer or Support |
95 | ROLL_TIMEOUT | hardware; insertion slot obstruction; ODD obstruction | Clear obstruction; Power cycle; Contact your Kaleidescape Dealer or Support |
97 | DRIVE_NON_EMPTY_DURING_DISC_INJECTION | drive; hardware | Power cycle; Contact your Kaleidescape Dealer or Support; Contact your Kaleidescape Dealer or Support |
99 | NEED_USER_ACTION_FRONT_BLOCKED | hardware; misuse | Clear obstruction; Power cycle; Contact your Kaleidescape Dealer or Support |
100 | NEED_USER_ACTION_DRIVE_BLOCKED | hardware; misuse | Power cycle; Contact your Kaleidescape Dealer or Support |
106 | EJECT_FAILED_DISC_STILL_IN_DRIVE | hardware (disc still in ODD after failed ejection) | Power cycle; Contact your Kaleidescape Dealer or Support |
107 | EJECT_FAILED_DISC_LOCATION_ | hardware (disc could not be detected after ejection from ODD) | Power cycle; Contact your Kaleidescape Dealer or Support |
110 | INTERNAL_DRIVE_MISSING | hardware (ODD appears disconnected or missing) | Power cycle; Contact your Kaleidescape Dealer or Support |
111 | FRONT_ROLL_TIMEOUT | hardware; insertion slot obstruction | Clear obstruction; Power cycle; Contact your Kaleidescape Dealer or Support |
112 | DRIVE_ROLL_TIMEOUT | hardware; ODD obstruction | Clear obstruction (requires taking off lid); Power cycle; Contact your Kaleidescape Dealer or Support |
