Lord of the Rings (Theatrical) Problem
SterlingMax
San Rafael, CA
I have both the theatrical and extended editions of all three LOTR movies. They show up in my library on the K website (and show up as downloaded).
But when I go to search my library, I only see the extended editions.
I did a search in the store, found theatrical, navigated to it and it showed as owned. So I played it. And it played ... the extended edition.
Has anyone else had this issue? Thanks.
If you have both the Extended Edition and the Theatrical edition downloaded, they will be folded into one entry on the onscreen display (we call this "Selection grouping" in-house). To get to the Theatrical version, open the detail sheet for the Extended Edition and on the side bar menu, select More Options > Play Version > <highlight the version you want>
You'll end up with this:
Select the Standard Edition from the flyout menu.
