lip sync test material and hardware
grit
I'm trying to calibrate for audio delay (lip sync), which I beleive is a product of my Sony A9G. I was to find something similar to the old Spears and Munsil discs on the Kscape store, but haven't yet. Any suggestions for similar material?
I also found an app for my iphone that records video/audio and lets you measure the offset. It's not elegant, but gave better results than trying to guess. I also found a device called "Sync-One2", which appears to be a $450 tool that will precisely measure audio delay vs screen display, if you can play either their config files, Spears & Munsil, or something similar.
Has anyone found anything else for accurately measuring audio delay (hardware and/or display material, like Spears & Munsil)?
Thanks,
- Garrett
Unless the synch rate is different for the K system than a player, you should be able to set using a Blu-ray player with the S&M disc and it will apply to the K. I did this today in fact. I used both the BD and 4K BD version of S&M to fine tune my AV synch with my Trinnov. I noticed a few titles were off a bit when watching my Strato. Sure enough, it was off slightly. After I adjusted with S&M (I checked both versions and they were the same) I went back to Strato and it was fine.
The pattern on the Spears and Munsil disc is designed to do it by eye. I have a Synch-One2 to confirm though and it gave same result.
Oh, amazing! I was considering a Sync-One2. So, in your experience, it seems like just doing it by eye gives you as good of a result as the Sync-One2? I'd rather spend my money on more Kscape movies if the Sync-One2 isn't making a noticeable improvement.
It works well but I generally get the same result by eye. Some people struggle with the pattern, but I don’t have any issues with it.
l tried by eye... and failed. I downloaded a $20 app on my iphone that records the video/audio from H&M (or anything I imagine) and lets you adjust the audio to fit the video, showing the miliseconds you adjust. It's way better than my "by eye" estimate. By eye, I adjusted ~20ms, but knew it still wasn't right. The app had me adjust to 68ms, and it's much better, but I feel there's room for improvement. But that could also be my source material too.
I've read that one should have different adjustments for HD vs 4k vs HDR, and at different resolutions. Is that accurate? It seemed to me that whatever the processing lag induced by my Sony OLED, it should be relatively consistant across forms/formats.
I also read that one should calibrate for various input sources. But if the same hardware (in my case, the TV) is doing the video processing, there shouldn't be any source delay, as you indicated earlier, correct?
Presently, I'm only using a Kscape Alto and Strato. I pulled my Oppo BDP-203. After the recent disc to digital upgrade sale, I don't know that I have a need for 4k discs anymore (or HD for that matter). If 4k vs HD vd HDR is all source independent, I won't bother putting it back in I think.
BTW, thanks for all of your input!
- Garrett
Again, some people can do it by eye, some can't. Also, adjustments should ALWAYS be done in frame integers (time of a frame) so one frame, two frame, etc. Not random ms like you did. A single frame is about 42 msecs, so use that or 84, or 126, etc.
I sent a note to Jim Peterson and asked what he used for his setup for 4K24 and 4K60. Used that as a starting point since he also has a Trinnov, Lumagen Pro and Strato (although we have different projectors). For some strange reason my Oppo 205 seems to do something different. I don’t use that much, so wanted another opinion for my Strato. Used the delay feature in the Lumagen. Just eyeballed the final settings with material that had a lot of talking. :) Still think it might be cool to have some audio test material that could be downloaded from the store... SJ
I have a Strato, Lumagen and Trinnov. The video isn't ahead of the audio, so you wouldn't use the video delay in the Lumagen. In my setup, audio was one frame ahead of video, so I added a single frame of delay to the master setup of the Trinnov and it was perfect.
You are the expert :), but it seems to work fine using the Pro for whatever reason. That’s what Jim did. He gave me the video delays based upon his setup. Who knows. Haven’t touched the Trinnov. Are you going to be doing Trinnov audio calibrations now? SJ
